Hi. I test drove a 2000 model today. It was equipped with a Select Trac transfer case. I engaged the Part - Time, Full-Time, and LOW on my test. When I went to disengage the four wheel drive it would not come out. The handle on the transfer case would move and the light would go out but the four wheel drive would not disengage. My question is, should I keep looking for another XJ with the command trac or if the dealer rectifies the problem will this transfer case give me problems. Any opinions would be helpful. Thank you.
