RWKHausSupply
- yorba linda, Cali
Homeowners and pros looking to upgrade to a serious combo kit can call off the search. The new Ryobi® 18V Lithium-ion Compact Drill is the star of a four-piece combo kit ideal for dedicated and determined DIYers. This innovative drill saves time and guesswork by automatically operating at the optimal setting. It makes drilling and driving easier and faster because you don’t have to select which speed to use; the drill chooses for you. For optimum adaptability, the combo kit includes two batteries. The high-capacity Lithium-ion battery provides twice the performance and holds the charge four times longer, optimizing charge cycles. An on-board battery gauge helps ensure the user won’t run out of power in the middle of a project. For work in tight spaces, the lighter weight compact Lithium-ion battery offers 20 percent more performance and reduces user fatigue.
I bought this kit for the free tool and the batteries out of it.
Kit is complete and new EXCEPT NO battery or charger or flash light.
Compatible with ALL Ryobi ONE+™ 18V BATTERIES!
Has the sawzall, the drill, the circular saw and the bag. ALL Still in packaging...
P202 Compact Drill
New ergonomic design is 15% more compact and 20% lighter weight for maximum user comfort**
1/2" single sleeve chuck with spindle lock for quick, easy bit changes
24-position clutch and 2-speed gear box increase drilling and driving control
MagTray™ magnetic holder for convenient placement of screws and bits
On-board bit storage
Top-mounted level for drilling and driving accuracy
P503 Circular Saw
Compact design for better handling
Front pommel handle for 2-handed operation
Left-side blade for better cut line visibility
P513 Reciprocating Saw
Toolless blade clamp for quick and easy blade changes
Ergonomically designed for better balance
Variable speed for cutting all material types
INCLUDES:
P202 Compact Drill and Bit
P503 Circular Saw with Blade and Blade Wrench
P513 Reciprocating Saw with (2) Blades
Tool Bag
Operator’s Manuals
Drill -
Motor:18V
RPM:0-440/0-1600 RPM (no load speed)
Clutch:24 position
Chuck:1/2 inch
Weight:2.9 lbs.
- Circular Saw -
Speed:4,200 RPM
Blade Size:5-1/2"
Depth of Cut 90° 1-9/16" : @ 45° 1-1/8"
Weight:5.3 lbs.
- Reciprocating Saw -
Speed:0-3,000 SPM (no speed load)
Weight:4.2 lbs.
70$ FOR EVERYTHING
Robert
714-875-2414
P202 Compact Drill
P503 Circular Saw
INCLUDES:
Tool Bag
Operator’s Manuals
Drill -
Motor:18V
Clutch:24 position
Chuck:1/2 inch
Weight:2.9 lbs.
- Circular Saw -
Speed:4,200 RPM
Blade Size:5-1/2"
Weight:5.3 lbs.
Weight:4.2 lbs.
70$ FOR EVERYTHING
Robert
714-875-2414
