Have you installed your mechanical temp guage yet?
230 is on the hot end but not uncommon on 90 degree days with the ac on
Yup and wasn't running A/C. About 97 here yesterday and shot up in about 20 mins driving home around town
You must be confident that none of the coolant passages in the block are obstructed from the cleaning process before the rebuild, which I have seen happen before as the block is hot-tanked and not all of the scale is removed, it becomes loose and may lodge itself between the cylinder walls, preventing coolant flow. Barring this, make sure that the coolant system has also been purged of air. This is more important than you may think. And also, as mentioned before, use a factory rated thermostat, do not continue using the 180 degree piece, this is too low.
So last ditch effort (aside from a plastic mopar radiator) is this 195 mopar thermostat and bleeding the back of the system. The mopar thermostat came with some weird valve thing on it. I've heard to just remove it so the hole is always open at the 12 oclock position. Good or not so much? Damn thing cost me 33 bucks so apparently its made from gold and unicorn marrow. Going to test it before installing with an IR gun and a pot of water. Oh and going to take it down and get the system pressure tested after its installed just to make sure I'm not crazy and theres some invisible leak I'm not seeing.
Won't ever buy another 4.7 motor.
If it's a 4.7 what have you done about the fuel injectors? Are you sure it's not running lean?
Get an ir temp gun and check your radiator for cold spots. Im guessing the tiny tubes on that 3 core either sat dry while the motor was being rebuilt and corroded up a bit or some junk in the motor plugged some up.
Just because its passing water doesnt mean the flow isnt restricted or half the tubes are blocked
i know on my renix i get air stuck in the back of the head by the dash temperature sensor. the dash gauge will show over 210 but the ecu reading is 195 ish. or maybe that temp sender is faulty.
I'd worry more about the condenser in front of the radiator blocking air flow than trying to find a mopar radiator. Unless you've got a particularly defective aftermarket radiator I don't think mopar radiator will solve the issue. If the fuel mixture and exhaust are correct and the problem is in the cooling system then maybe it'd be worth swapping out the radiator again. I'm still puzzled how it was working fine before the rebuild to suddenly have trouble.
I'm forgetting where the radiator comes in this saga, I was under the impression it was new replaced while the engine was rebuilt.
If it's is new and the previous radiator is still around maybe swapping the old one back is an option. If it's not, and since the mopar three row seems unavailable I would either try to warranty the new radiator (if it is new) or just buy another metal 3 row radiator and test it.
It is acting like a clogged radiator if we assume the water ports in the block are clear and the water pump is good.
I still don't understand why the reservoir is not seeing a change with the temperatures.
The OP has done a lot of trouble shooting. I believe he put on a mopar O2 sensor. Not sure if he's tested it with new radiator cap yet.
Because he's done so much trouble shooting I'm thinking it's got to be the radiator or water ports in the engine. Maybe bad water pump.
Replacing parts is NOT Troubleshooting. It is taking shorts in the dark at a dart board. :laugh3:
Testing the O2 sensor voltage or scanning it with a real scanner to see if it is closed loop and or if it is running lean with test (troubleshooting) equipment is troubleshooting.
I just read the whole thread, he has not yet confirmed if he has even done a second test with an infrared tester at the T-stat housing to confirm that the dash gauge temps are even correct. He could have a sensor ground issue caused by moving the harness around in the engine swap or something like that.
I chased my tail for 3 years on mine. The problem vanished when I replaced the donut in the exhaust manifold outlet flange. A $2 part. :twak:
It escaped three muffler shop inspections. Only leaked under load on the freeway blowing exhaust gasses on the block 1/2" from the Exh Pipe flange. The old donut had been reused by the PO when it should have been tossed.
Haven't reread the whole post but did the water pump get replaced recently? The pump from the early Renix 2.5L looks identical but has the impeller reversed and can cause a ton of issues. They sometimes get switched at a rebuilder.
