2001 Cherokee XJ with the LP Dana 30. RE 3.5" Super ride lift and 31's.
Advanced adapters SYE with tom woods' rear shaft.
Getting rhythmic vibes around 55 mph, and they progressively worsen thereafter.
I shimmed the rear with a 3° shim, and the vibrations stop when the front shaft is removed. So it's either in the shaft itself, or the angles.
Just had an alignment done and caster is within spec. Measured pinion angle/vs drive shaft angle, and they are 7-8° off... so, my understanding says, that difference will cause vibes? Is this a fair thought?
Just looking for help with solutions here? Multiple double cv shaft? Adjustable upper Control arms? Kit came with fixed lowers. Maybe just an old front driveshaft is the reason for the vibrations?
Thanks for the help
Thanks for the help
