urbexx
- Glendale, AZ
Ahhh that's exactly what I had in mind! So those are called well nuts? Nice speaker wire btw
Yep. The actual/technical term for them are well nuts, but they're more commonly referred to as rubber expanding nut. Big thing to keep in mind with those is just not to over tighten them. Snug them up just to the point of sealing, and that's it. Get a couple extra as you're likely to over tighten the first couple and pull the nut through the rubber. Oh yeah, I forgot to use washers underneath the terminals on the top, and that's why they're bowing like that in the pictures. Use washers, or ring terminals that cover the entire top, and they won't bow Other than that, they work great.
As for the wire - I often use speaker wire for these types of hookups. More flexible/easier to route, and it's incredibly convienent to have the positive and negative lines bonded together like that I even have some of that flat style home theather cable run in certain areas due to space constraits
