Prom3theus
- Cleveland
Hey folks,
I have a starting issue when engine is warm. Before details about the issue: 99 XJ, 4L, fresh tuneup (few months ago), new O2 sensors, about 125K miles.
I have no CEL light and when I try reading the codes from ECU I get none (not even a pending). I have noticed the issue first time couple weeks ago. When cold, engine starts and idles normally, however, if I attempt to accelerate half pedal, the car stalls (does not die, just stalls, then eafter I release the pedal, it picks back up). Sometimes it sounds like it has a backfire (I hear that "bang"). After letting it idle for 10-20 seconds, it drives almost perfectly, but I can feel it doesn't ride at it's full potential (it feels like it's accelerating at 70%-ish from how it would normally). When engine is hot, and I stop it for couple minutes (turn off), it barely starts, and it idles very rough and almost dies. I can also smell it runs very reach. After again 10-20 secs, it starts to improve and in few more other seconds, it starts idling normally, but I have the same lack of power as when cold. If I just stop it and immediately start, it starts and ides fine, like it hasn't been stopped at all. Every now and then it runs normally (I fell it accelerates way better), then again at about 70%ish from it's potential. I have new IAT, TPS, MAP, CPS, idle control valve (from few months ago). When I first noticed this, I had a CEL for vacuum pump (sorry, do not remember the code), but it suddenly disappear. I had changed the vacuum pump also just in case, but with no results.
I would like and appreciate some suggestions in what could be the cause, I know this engines can be finicky and fortunately I haven't had such issues till now. I am surprised I have no CEL at all. In my opinion it could be from the coil, I will replace it tomorrow since I have a spare one. I also think it may be related to the evap system, but I have absolutely no extensive experience with this engine and again, I'd appreciate any suggestions. Thanks a lot!
