87CherokeeChief
- Sacramental
bgcntry72 said:I was just reading the post again, and noticed that no 'others' mentioned this.
Am I missing something?
my templates were in the pinch seam mount...
bburge said:Yes, I think it's an issue with the step side ones. I have them so I can load my roof rack.
I have the same four dimples in my quarters as well....
bburge
87CherokeeChief said:just curious but anyone who has the steprails and have had problems; have you talked to RRO about it? and if so what did they say?
also has anyone added some more structuring to the step rails, such as a few more pieces of square tube or something of the like, becuase that would be very helpful for some guys...
Ramsey said:i dont see how support there will help. now one or two more giong to the frame rail would be nice. something i might do in the future.
looking at it again it seems like his twisted up and actually bent. mine dont seem to have that problem
The guy that built my step-rails used RROs basic concept, and we noticed they both have a tendency to flex up into the body although the steps do their job of protecting the doors. His newer version uses more bracing, along the lines of what you indicate in the pic...that reminds me I need to drive cross-state and see if he'll redo mine as well.EricsXJ said:Actually I have also been thinking about reinforcing them but not sure if it will help or not. Something more along the lines of this (yellow lines):
Or possibly adding one length of square tube running the entire length between the legs to the frame and directly under the rocker. Basalt51, what do you think about either of these ideas?
Unfortunatly he just recently went out of business.y2kxj said:for those looking for rails that act as steps and stick out far enough to pivot with (past flares and door handles) might I suggest AJ's http://ajsoffroadarmor.com/
Better, sturdier design and you can customize them when you order. Great prices and customer service also.
87CherokeeChief said:Here is what i mean by adding some support, just simple short pieces of square tube welded in...
(This is CaptainRon's pic BTW, hope you dont mind Ron)
sorry bout the small pic but i think you get the idea.
Captain Ron said:I think I'm going to add 2 additional cross braces all the way over to the frame rails, and add another tube on the other side of the pinch seam. Pinch the seam, so to speak, and thru bolt both.-ron
