Hellbent
- san diego, california
that makes sense. thanks.
gorman said:Must admit, I didn't even think of sleeving it, but I do see how it will be more sturdy. The way it is currently I'd say is stronger than self tapping screws a lot of sliders are mounted to the frame rails with and those seem to hold up okay.
Some time soon I need to weld up another set of sliders for a friend - in doing that I'll remove mine to get the measurements again. That will be a good time to do the sleeving. Thanks for the tip on how to do the sleeving!
Oh yes they do when you fall of one ledge and onto another and land on the rock rail there is a lot of loadRCP Phx said:If properly supported on the pinch seam the framerail mounts dont see alot of loading.
mecompco said:This is one reason I went with Rock Lizard's--they provide crush sleeves for the uniframe (we tacked them in, after drilling the holes) and the pinch seam rail is bolted through instead of relying on self-tappers. I also liked the diagonal braces like the poster above has added to his, ala Rock Lizard. Shame they aren't making them anymore. No offense to JCR--their products are awesome as well.
97XJ2 said:whats done with the pinch seam? do guys just put a hole through it is there any special prep to be done, i dont know maybe its just a mental thing of mine to want to try to not mess with the pinch seam. im designing my own (since i get to use autocad/inventor at work) and my friend will be fabbing them.
don't forget the primer and paint before you put the bolts through, for those living in the rust belt.Haleyes said:Just drill a hole through the pinch seam. All quality rails will have some sort of pinch seam attachment. Most will be attached with a bolt through it.
Hale
87manche said:don't forget the primer and paint before you put the bolts through, for those living in the rust belt.
