RWKHausSupply
- yorba linda, Cali
http://www.rwkhaussupply.com/magento/90-01-cherokee-xj-7.html
A great front upgrade!
Rock Krawler is proud to bring you the XJ X Factor Plus Long Arm Upgrade System. The X Factor Plus Systems are the best performing trail systems ever made for Cherokee XJs! These systems feature our revolutionary independent 3 link front end with track bar. This design dominates the professional world of rock crawling while also maintaining perfect streetabiliy and precise handling. The upper control arm is full length so caster change is kept to a minimum. The lower control arms are made of 2 solid alloy steel and use a Monster Bushing at the frame connection and Monster Krawler Joint at the axle connection to provide the ultimate in twist! The front upper bushing in the differential is replaced with a build a ball joint for maximum articulation. Even the tinniest of details has been addressed with the X Factor Plus systems. The new long arm mounts are made from 3/16" thick laser cut steel and are precision welded. Simply put, we feel this is the strongest, best articulating, long arm upgrade ever made and we back that up with our Abuse Proof Lifetime Guarantee on all hard parts!
System Benefits:
-Excellent Highway Ride and Handling.
-Revolutionary Independent Three Link Front End for Awesome Flex and Control!
-High Clearance Lower Control Arms Made from Massive 2 solid alloy steel.
-Bolt In Long Arm Mounts. (recommend welding to frame stiffeners)
-Limited Lifetime Warranty
System Includes:
(2) Adjustable high clearance lower control arms made of 2" solid alloy steel, (1) adjustable front upper control arm made from 1 5/8 solid alloy steel, (2) long arm mounts from 3/16" thick laser cut steel, (1) front differential spherical joint, hardware and detailed instructions.
*Recommended lift height range of 4.0" to 6.5".
**Requires removal of the factory lower control arm mounts.
***Recommend welding of the crush sleeves in the frame.
Also available: Triple threat (4 link front) as well as Currie lifts at 25% off!
System Benefits:
System Includes:
