well I was a OG guinea pig for thier krap. I though was in a TJ and did thier full rear tri-link and had to swap out to my own fabed triag. 4 link after thier rear upper wish bone snapped, causing my CV to buckle and loosing my rear pinion, the CV shaft, and 2 bent shocks..
They were nice enough to replace the wish bone though. Now GIVEN THAT WAS BACK in dec 02. But during that time of thier first designed TJ kit, I went though close to 30 of thier "better then QA" heims. So when they came out with thier "krawler" joints they replaced my heims with those. Well about 2 wks after getting all the new joints the rear failed as I stated up there.
So when I redesigned my own rear setup I figured I would save money and reuse thier joints and put them in the upper locations and get some curries here locally for the lowers. Well here is what happened to the High end joints. Now I think thier new ends are much improved and as stupid as I am, I may be going with thier long arm and hope thier ends are as improved as they look...
Ok first.. Currie on the right RK on the left.
What the washer looked liek after about 450miles of road driving in a upper that was laid down and put Very little stress on the joint.
And how I knew it was having issues.... This was after they sent me a "new designed hardened washer". After this I went all Currie's.... As you can see the washer blew out and the end fell in the center ball....
