funwheelin
The majority of the loading on the heim joint is radial, there is always some axial load on a sperical joint do to the misalignment. RK is confident that you will not have a problem with that heim joint at all.
As for adding another arm to the passenger's side. That would defeat the purpose of the design. Then it would not be much better than a standard short arm system.
Thank you for your opinions.
