- MilkyWay Galaxy
So are you telling me it's time to shoot it and put it out of my misery?:tears:
It did have large hard dry carbon chunks about 1/4" think in the valve cover area laying in the head recesses. . And the PO was getting 24 mpg out of it stock, so it was probably running a wee bit lean (which no doubt helped burn the head gasket). He was also running it at 220 to 230 F, no electric fan when I bought it.
But you did not give me a precise answer to my last question. I am more of Duct tape guy, if it ain't broke don't fix it, so maybe I should be asking how long it might last if I don't do the rings and bearings.
My other problem is it will be my 18 year old daughters first vehicle. I suspect she will outlast it, or in other words the Jeep may not get the chance to wear out the engine before?:bawl:
5-90 said:RENIX doesn't need one - it's got ears you can get to with your fingers (or longnose pliers, in a pinch.) I've not needed tools to pop RENIX fuel lines.
Sounds about like the PO ran it a little faster than normal - my 1987 pretty much lived at 3200rpm and under for the 170K or so that I drove it (and I didn't lose the oil pump until 120K into my owning it. I'd probably still be driving it if I'd put new rings in, since I was there anyhow...)
