caspergotaz28
- Southeast, TX
Replaced all four pads. I did not turn or replace the rotor. I lightly sanded front and back with 220 grit in a swirling motion. They had some tiny "gouges" on the surface, but I didn't think they were too bad. For the most part they were flat across.
The rotors are original with 96K miles on them. I know this because they have those funky washers on the studs that hold the rotor on for the trip down the assembly line.
I did a 10 mile test run and they seem to be "grabbing" the rotor lightly. The car will slow to a stop faster while in neutral and the engine is running at a slightly higher rpm to maintain speed. I did very light braking throughout the test drive. Mainly 45-20 slowdowns.
When I stopped, there was some thin smoke coming from one of the wheels, the other didn't seem to have this smoke. I could also obviously detect a burning smell.
I didn't replace/turn the rotors in the interest of saving money. I will if it is needed though.
-Should I drive another few dozen "break-in" miles and see if the condition improves?
-Should I replace the rotors or turn them? They are original and never been removed from the car.
-Should I replace the wheel bearings if I'm gonna pull the rotor?
-If I turn/replace the rotor, should I start over with new pads or try to use these ones with a few dozen miles?
I have done one other brake job on a mustang and I turned one of the rotors and replaced the other. I had no problem like this happen.
