Tally_XJ
- Tallahassee, Florida
I been searching this forum for a long time trying to get all the info I need to do some of the things I am planning for my RENIX XJ.
I am about to swap in a motor and would like to use the HO head and/or throttle body.
I have been searching for a way to wire the HO tps into the RENIX wiring harness so I dont have to modify the sensor. Can this be done?
Also, I have the 2001 WJ brake booster to do the dual diaphragm upgrade. I do not have the master cylinder yet. I have access to a Pick-n-Pull yard and could get a master cylinder a lot cheaper than new, however, there are no WJ's in this yard at this time.
Which other master cylinders will fit this booster other than the WJ master?
The master off of a 1999 XJ will not fit, the mounting bolt width on the booster is wider than the XJ master.
