outlander
- Columbus,Ohio
you sure you don't have some weird radiator cross flow problem or maybe air trapped in the system that turns to steam at the temp gauge sensor causing the gauge to read hot although the motor isn't?Did you verify its operation in a pan of water like before?Also I wonder if your gauge is giving you accurate info.
Sounds like it's really time to do the vette switch mod.....
