Re: Death wobble from hell at 5 mph, LOL
Here is the entire story on this wild ride with Death Wobble!!!!
First problem was I tried to reuse what turned out to be a bent internally cast aluminum wheel/tire assy. 1/4 " wobble side to side at the rim edge showed up on a spin balance. It was damaged on the 89 when it got totaled/rear ended and rolled on the freeway in Nov :bawl:.
But before I discovered it, we replaced the tie rods ends, drag link, track bar,
steering stabilizer (Which had been removed when the bushings fell out and I found it rattling around weeks earlier)...steering parts (Pitman arm and Ball joints were still OK), and
one bad lower control arm was changed.
Then we botched the toe in adjustment bad and the DW was horrendous at even at 5 mph, LOL (not just at 48 mph). She was jumping and hoping all over the place at 5 mph. We had seriously botched the tow in, somehow we had it a 3"s of tow in. :eyes:
Figured out the botched measurement on tow in and fixed it, now at 1/8" and the tire balance test showed the bent rim. Fixed both (replaced the rim), and that pretty much fixed it up to 35-40 mph (did not test any higher speeds yet, at that time).
But I was supper picky at that point and replaced the bad front shocks that made her ride a lot better on bumpy roads. One shock had real serious issues.
Adjusted the tire pressure down a little and
she steers herself now, hands free on a straight road at 60 mph
The original 48 mph DW was no doubt mostly caused by the bent tire rim, with some help from a bad bushing on the lower control arm and not having a steering stabilizer on her anymore!!!
The other parts were ready to go, time to replace them, but I doubt they were the cause of the DW. A 1/4 bent rim at 45 mph is not good!!!! The crazy thing was the tire was OK, it is on the jeep still, but the rim looked perfect, unscathed by the accident, no contact marks, so I have no idea how it got bent with out any signs of an impact on the rim???? Only way we detected it was bent was using a slow spin on a tire balancer.
During the servicing, the wild bucking horse ride at 5 mph, was the 3" toe-in fork up, LOL, on top of the bent tire rim.
So if I ever want to build a rodeo ride bucking jeep for rodeo fans, :laugh: I now know how to it, LMAO. It was literally hoping up and down and side to side, nearly loosing road contact at just 5 mph to compensate for the sever toe in.
So it was not the engine or drive train, or knock sensor.....etc.
