- Roanoke VA
90' 4.0
What is the best way to disconnect and clean the bulkhead connector? Does it come apart from the inside or outside? This is the only connector I have yet to remove and clean. I do not have the FSM for my year model, only the RENIX FSM and its not covered there.
I run a air tube instead of the factory air box. Would I gain any performance by mounting the MAT sensor in the tube instead of the intake manifold. I feel it would give me a "true" air temp reading and not pick heat up from the manifold like the stock location does.
Also I need a good source for the MAT, no one locally can get one for me including the dealer. Most online sources are no longer in stock as well. I can use a CTS in the air tube since the MAT/CTS are essentialy the same sensor just the CTS is enclosed. I can't use the CTS in my manifold unless I drill and tap for the larger NPT size. The MAT is 1/4" NPT and the CTS is 3/8" NPT. I don't want to drill and tap the intake while its on the Jeep.
I plan on running the MAT sensor in both the air tube and in the manifold and put them on a switch so I can swap back and forth from winter to summer.
