FlyNNN
- Edmonton, Alberta
A two-door, wow! ... I would grab that coolant pressure bottle if it isn't cracked around the hose nipple, and also the ECU if it is in there. Probably the B+ latch relay or starter relay (the funky one with the stud on it, iirc) as well. You never know when your ECU is gonna kick the bucket and there are only so many '90s left out there.
Is that a dana 44 rear or a dana 35? It looks like the 35 from the drum brake size, if it is, leave it there.
Also, for future reference, don't bother buying junkyard mechanical fan shrouds, they are always brittle and break easily. And you can get a new Keystone manufactured unit for almost what the junkyard will charge for a well-used one, just order CH3110104 from any Keystone dealer or online parts house. Fits 87-01 4.0L equipped.
I didn't bother with the coolant bottle, I installed a MAC's surge tank a couple of months ago.
I also picked up ECU & ABS modules a couple of months ago as well. I even posted a YouTube video of the inspection for anyone interested. http://youtu.be/0TQGgDJlDXY
How can you tell its a Dana44? This was a non-ABS, so it could be possible. I don't think I'd want to attempt trying to remove it. These vehicles are teetering on up-turned rims.
I was just grabbing parts like this was the last one on earth. Funny, the fan shroud seemed to be OK whereas the electrical fan shroud has some cracked corners. I JB welded them today and will see how that turns out. Thanks for the Keystone #.
