rockwerks
- Chito Beach Resort, WA
I tell ya you can always go buy another nut. this is the way to go. then a pickle fork and BFH to get the bolt out. a 5 minute operation then
A ball joint or tie rod separator.tarantula8 said:(I understand what the BFH means, LOL, but what is a pickle fork)?
D
It would have helped if you had searched for 'shackle' not 'shakle'.tarantula8 said:Before posting my question I clicked the little button that said "Has this question been asked before?" and no match came up. So I asked the question. Eagle, what should I type in for a search on this topic?, I have search the archives by just looking at individual post and can't find anything?
Beej said:It would have helped if you had searched for 'shackle' not 'shakle'.
canadianwheeler said:I got my driverside spring nut spinning inside my frame (unibody)right now. I tried cutting into the frame from behind the bumper with no luck. I just gave up and returned the shackles and bought a 2 inch block. Maybe someday ill get that bolt out.
steagall9301 said:"I got my driverside spring nut spinning inside my frame (unibody)right now. I tried cutting into the frame from behind the bumper with no luck. I just gave up"
dude, go through the floor of the jeep, depending how loose that is it could be BAD JOO JOO!!!!
