Well......, a 1" lift shackle will raise your vehicle in the rear by approximately 1". So if your junk is 1" lower in the back, than the front. Yes it will help
Not to bust your balls but I would get rid of those gay lastarawheels first. You would probably get a better ride from a good set of 4.5" springs, but if you already have good springs, I would use a 1.5" shackle.
Don't forget, if you are entirely level in the first place, there will be a larger gap in the front....because the rear flares are mounted 1/2" lower than the front flares. So the gaps between the top of the tire and the flares can fool you into thinking it's sagging back when it really wasn't. You really have to look at the rocker panels and their relation to the ground for their entire length.
