jeepinairman
- wichita, kansas
okay ...this problem has progressivly gotten worse the longer i own the jeep...its an 89 ...4.0.....3'' rustys sp.....31x10.5x15.....
sometimes (well....most of the time nowadays) when i BARELY press the brake pedal the rear wants to lock up and slide.......when we had everything apart doing the lift we checked the brakes out and the fluid and everything seemed fine...except for a bit of rust in the brake components in the drum assemble.....everything looked okay....well we put the lift on and for about a week or so it didnt do it......but now after wheelin on sat......its been really bad......EVERY time i BARELY hit the brakes the rear wants to slide.. :flamemad: ...what should i check first?????....i am slowly learning more about brakes..i just want to know where to start to save me buying all those expensive parts if its a quick fix...
thanks guys....
thanks guys....
