- Port Orchard, WA
DDawg16 said:I did the H&T to my wife's 242...no issues. I hadn't thought of trying it with the shaft spinning....then then again, I used masking tape to mark where I was cutting. If I were to do it again, I would use that method.
Centering the hole is easy....draw an X with a scribe or spin the shaft. And as correctly noted....if your off 1/16", no big deal....plenty of room.
Considering how long it takes to just pull the xfer case...the H&T takes about the same amount of time....and you don't have to re-install the xfer case.
i didnt pull the t-case off to do my AA SYE, and frankly it was just as easy to do it under the car as it was on the bench (i blew up the t-case and replaced it with another one and swaped the SYE on the bench a week later)
