BRADFORDXJ
I am just curious if anybody has tried these... I have heard a bunch of bad things about the 1st gen. Wanted to see if I am going to kick myself for not upgrading to the jks when I ordered my kit.
krelja said:http://www.rubiconexpress.com/dynamic/mainpage.asp?folderid=1306
the first 3 are the Gen 2's the don't come apart like the gen 1's they slide off a pin on the bottom and are held up by a similar one mounted elsewhere. The gen 1's get the whole middle section pulled out and have nothing to hold the swaybar outta the way.
SLAYER said:Ok so the gen 1's and 2's dont come with something to hold the swaybar out of the way. Ever try a bungie? takes 10 sec on each side.
As far as the Gen 1's falling apart, what exactly falls apart? bolt up the sway bar relocator to the uni-frame, the stubs bolt on to the brackets on the axle, u slide the center shaft on, and put the clips in. All they do is rattle around. And if your stupid enough to keep them on when wheeling, then u have to be kidding me. Ive seen dumshits snap em like candy and mess all the bracketry up.
SLAYER said:JKS.
Done.
RE needs to dump their line of disco's.
CRAP!
