Black1990jeep
- california
It's not at all difficult, just tedious and definitely need the right tools.
Digital micrometer
Travel Dial indicator
Torque Wrench
Carrier & Pinion bearing puller (or bearing separator)
Hydraulic Press
Set up bearings (can use old bearings)
A plan ole micrometer will work, no need for digital.
The arbor press need not be hydraulic. A rack and pinion type can work too.
In some cases a case spreader may be required, but sometimes a nite in the freezer for the carrier is enough to get it to fit the pumpkin. I have done it both ways.
lots of patience if first time, golly I made over 15 patterns on the gear the first time. But got better at it on subsequent jobs.
