I currently have the DBs waiting to be installed and would like to do stiffeners as well. I can't seem to find any resources on this combination. Anyone done it themselves or have a link?
I have RC drop brackets with RE braces and Ruffstuff stiffeners...I had to ream out the holes a bit to fit them on, but they work fine...I drilled and tapped for an extra bolt also
Edit...almost forgot...I drilled and tapped an extra hole on each side for the crossmember also. I didn't like how little engagement I had on the crossmember stud. I can still fit the nut on there, but not enough for me to be happy with
Nope - I have the Ruffstuff weld on frame stiffeners...but with the extra thickness of the stiffeners (3/16") and the RE brace, the stud on the crossmember wasnt quite long enough.
Oh, so you're saying you reamed out the holes on the brace so that it could still bolt to the drop bracket while sitting on to of the stiffener is that right?
I must have underestimated the extent of which the braces attach to the DB... I'll have to give that a look.
Yeah, with the stiffeners on, the brace will sit a little different...Like souske said, weld the stiffeners on first, then you'll figure out how much you need to move the holes.
