I have a Re 4.5 super flex lift with 31" tires i am about to go to 33" tires and would like to increase my lift about 1" to 1.5" any ideas on the best way to do it?
coil spring spacer in the front and lift schackle in the rear, for that much lift your shocks should still be good, just adjust your trackbar out a little further and check the front end alignment. You may also need to adjust the rear pinion angle with some shims.
Right on you dont need to add any lift to run 33"s with your lift. I run 33"s with my 4.5" lift and there are plenty of people out there that run 35"s with that much lift. Just trim a little and bumstop you'll be fine.
