Todd XJ
- Arlington, VA
I recently traded in the 2001 XJ, so here are all the parts that either sat in my apartment that I never got around to installing or that I pulled before trading it in. I live in northern Virginia, so keep that in mind when thinking about shipping (either USPS or UPS). If it seems way off, make an offer. Reply or PM me. I can send pics of some of the stuff.
Thanks,
Todd
The following stuff is brand new and never installed:
Set of upper and lower control arms with bushings - $40
Radiator for a 5 speed (no tranny cooler) crimped plastic reservoirs. $80
Set of oxygen sensors (Two with short pigtails, two with long pigtails). $50
Water pump and gasket. $25
Mechanical fan viscous clutch. $50
The following stuff was installed and got pulled:
Factory overhead console - $100 NOTE - The wiring connector for the lights and the trip computer is not the same as the factory harness. You'll either have to build a wiring harness for it or buy the factory wiring harness and modify it to work with what's on it. I was too cheap to buy the factory harness, so I built one. It's not tough and I'll give you instructions and copies of the factory service manual to figure our which wires to tap into. The computer works like a champ.
I also have a factor service manual for the 2001 XJ. It's used and a little greasy here and there, but all the pages are still there - $40
Thanks,
Todd
