streetxj
- Pembroke Pines, FL
Here's an update on the situation. Before I changed my wheels, my dad took the truck to the exhaust shop where they have done work on my jeep before. They have been there for a long time and they do a great job. The part of the stock down pipe that had the infamous dent/pinch was replaced with a smoothly bent piece by them a little more than a year ago. Later on, I noticed that my stock downpipe is actually 2.00 inches in diameter which then grows to 2.5 inches suddenly. The whole thing is mandrel bent at the factory, so that's a plus. That's how all factory 96-99 4.0 XJ down pipes are. So, I wanted to replace the 2 inch section with a 2.25 inch pipe from the header collector to a bit after the point where it turns into 2.5 inches right before the 90 degree bend before the cat. When he got there they looked at everything and even unbolted the down pipe from the stock 96' HO header. Then they told my dad that the stock header collector was 2 inches (I've read that the stock header outlet is 2 inches so it's a legit statement) and that they couldn't make a larger diameter pipe that would fit properly on the stock header collector. Then they've mentioned that if I want, they can install a larger pipe right under the stock diameter flange of the header (leaving a small section of 2 inch pipe), but it was going to be 60 bucks.
Thats when they told my dad that he would just be wasting money in putting a pipe that is larger than the header outlet and that removing the factory pinched pipe was good enough, which they already did when they first worked on my exhaust. At least they were honest. They also told me that in order to install a larger diameter pipe, I'll need to install an aftermarket header with the 2.25 inch outlet/collector to make it a worth while modification. I would like to get your opinions on that.
