RideFree416
- Littleton, Colorado
Hey gang,
Gotta a noob question for ya on a 96 SE. Im putting in a new radiator because the port were the upper hose connects to the rad. was in pieces when i popped the hose off to inspect a little leak. got the old one out tonight putting in the new tomorrow and had a few questions.
When I fill it I fill it through the radiator till its full right? After that i was going to run the jeep with out the cap on to let it bleed itself for about 10 min/till i stop seeing bubbles with the heat on high and look for leaks. Then let it cool down for about 20 min and see if i need to top it off. Am i checking/filling the bottle for this or the radiator?
Thanks
Thanks
