- Hartsville, South Carolina
Where can I find out more info about this race series?
This is the main site: https://proutvracing.com/
Rule Book:
https://proutvracing.com/racer-rulebook/
Sweet race Xj!! Aren't you one of the enlisted budget video guys from YouTube? And what tail light boxes are those?
Sooo... where are the updates?? How's the race Jeep holding up? Who won 1st place?
She seemed to run good at the LRG race. I assume your comments mean the CPS did not entirely fix it? I need to try and shoot to spectate and help that August race so I can see what I'm trying to get my self into....
No it is still acting up. A few people mentioned heat soak which isn’t totally unrealistic. Heat wrap kits for the rail and injectors + Intake shield are cheap enough and wouldn’t hurt regardless. Also found a heat resistant sleeve for the fuel delivery line since its fairly close to the exhaust manifold.
I could use the help in August! It's quite the spectacle regardless of the race outcome. It will be at Windrock. Race is on Saturday August 17th.
Have you talked to Jody about heat soak? He posted what they did when he was at the dealer for that somewhere on NC4x4. Windrock? I thought it was AOP?
I believe there is a recall to address a heat soak issue on the late model 4.0s. I will get with him and see what he says.
Yes Windrock.
https://prorockracing.com/pages/events
So after Winrock there is one last race in Rush, KY?
IIRC the 2000 had dual cats on the down pipe from the exhaust manifold. I could be wrong.... Maybe find a97 or 98 or 99 single cat manual computer?
