If you do snap off an end stud don't go nuts. Sometimes they just break and fall out on their own. My 96, bought used, came to me with no end studs (front or rear). I decided to drill and replace when I needed a new exhaust manifold. Drove it for around 6 years with no end studs, never gave me any issues. I snapped an end stud off on my 88, never caused an issue. I eventually got around to replacing it.
I never had any real trouble with the header to cross over pipe bolts, Renix or HO. I soak them with penetrating oil, clean the exposed threads with a small wire brush, re-soak and remove. I did put new nuts/bolts in my Renix.
If you do need to drill a broken bolt out, Cobalt drill bits are the only way go. They last twice as long as regular HSS drill bits. Cobalt bits are a little pricey, but IMO worth it.
The way I put them in and take them out is to put two nuts on the stud tighten/jam them together and try to turn them out with the bottom nut and tighten them in with the top nut.
You might try wiggling that back stud a little and see what happens. Knowing when to stop can be your friend.
Put a nut on the end of the stud that goes into the block and cut it to the same length as the original. Turn the nut off to dress the threads a little, maybe touch it up slightly with a file, a slight bevel. High temp anti seize both sets of threads.
Galvanized/zink platted anything is usually soft metal and not hardened. Your new studs are likely pretty soft. SAE Grade five if you are lucky, likely Grade 2. They don't need to be super tight, the middle bolts do most of the work.
The Cat flange bolts, get them out anyway you can, Try to unbolt them, if that doesn't work and the heads are still good, tighten until they snap. If the bolt heads are screwed up you may have to cut or grind the heads off with an angle grinder. If you have a nut splitter use that. Replacement bolts should be hardened, coated/plated and anti seize.
Stubborn nut or bolt trick, heat it with a butane/propane torch (doesn't need to be red hot) I've even used a heat gun. Then quench it with spray oil, repeat. A few cycles of heating and cooling usually breaks the bond. Works like a million bucks on brake lines.
^ thank you.
Yeah. It and to overthink things sometes but to be honest I'd rather overthink and not f up than just do and create much worse problems. I'm still new to a lot of mechanic work.
Do you have a factory service manual?
If you're going to be particular about doing maintenance the right way you might as well go all out.
I'm not trying to beat up on you. It's just interesting that you're willing to concede not using a torque wrench on your manifold bolts but you're concerned about the length and material of the bolts that hold the downpipe to the donut gasket.
If you can handle a little ribbing you'll fit in just fine.
Haha rib away.
Good point on the torque wrench part. I asked and I got enough answers from yall that made me feel ok. I may still try to use a torque wrench on the top bolts.
I know sometimes you need special hardware. When I ask a question that simple just chime in "regular bolts, you idiot."
