saburai
Hi Gang!
I'm going to hop on the train early AM tomarrow and head out to Long Island, pick up my truck and head over to a guy with a donor XJ. I'm pulling the cruise control, over head console and washer bottle/pumps from a wrecked auto trany 2000 XJ I found on craigslist.
The parts are going in my AX15 1999 XJ. I did a lot of searching the last week or so. I know that search is my best friend, but I could use some help summarizing my info.
This is what I've come up with so far:
Cruise Control parts:
*Cruise Control servo assembly (servo and attached cable, make sure to take the vacuum hoses as well)
*Clockspring assembly (located behind the steering wheel, the one for Cruise Control systems has an extra wire)
*Left and right Cruise Control switches ('99-'01 are not interchangeable with '97-'98).
*Y-cable that goes between the switches and the clockspring
*CC brake switch - Do I need this on '99-'01?
*Relay - Where is it? In the power center? Which one?
*Vac hoses
*Clutch Switch - Obviously, the auto donor truck will not have this. Will the CC work w/o it? Is the switch normally open or closed? I of course plan on installing one at a latter date.
Am I missing any thing?
Is it worth it to pick up a cheap steering wheel puller?
Over head console stuff:
I searched this too.
From what I gather, it's pretty plug and play.
Am I correct in assuming that I just connect it to the dome light wires?
I don't remember if I found any concrete info about the sensors and associated wiring. Is it already there on my '99 sport?
On the donor truck where do I find the sensors?
I think I'm good on the washer bottle:laugh2:
Many, many thanks!eace:
*Vac hoses
