- Billings MT/Rapid City SD
On my 89 I just cut the temp sensor wires from the rad. and ran a switch/solenoid from them.
Ralph said:On a 96 model the relay is energized on the ground side. Simply run a wire from the ground side of the relay from under the relay box to a switch and then to ground. When you flip the switch you energize the relay and turn on the fan. No muss, no fuss. Works fine and lasts a long time.
CODevilDog said:Is the compresor on the 96 hard wired? I had the same stuation a month or so ago and just unpluged the compresor and ran the AC. Fan on, compresor off.
Yeah but I was hoping for some sort of way to keep the stock temp turn on in case someone other than me drove it...i practically need to write an instruction manual on how to drive the damn thing. It turns on with temp right now, but not AC. It's a 98 btw if that helps.Jess said:you can run wires into the connectors you have the switch in and run the wires into the cab (with an inline fuse) to a toggle---then you can turn the fan on/off as needed.
Israel said:X2. I did this on my 96 for a couple weeks until I was able to replace the fan clutch. There is a wire connected to the back of the AC compressor which I disconnected. After that, if I needed some extra cooling, I would set the interior controls to AC and it would turn on the fan, but not the compressor. Kind of sucked not having AC for that couple of weeks, 'though.
I just unplugged it, is there something else i need, there's a bunch of small wires attached on it.PornstaR said:Ummm ok, didnt read all the posts here but some are over thinking this whole thing...... if you just need the E fan to turn on and off just un plug the ground on your AC pump (just the ground lead on the top of the compressor) and use the AC controls on your dash. As for all the other problems yall are having on fans not turning on and such, all your rigs are diffrent years so sensors, placement of sensors and types of sensors are diffrent.
Renix- uses a temp accuated *on-off* switch in drivers side of radiator to run the E fan
HO- Uses a signaled switch on the thermostat housing that tells the computer to turn the fan on and off.
Pretty much figured all the diffrences between the pre 90 and post 90 because I swapped my pre 90s cooling system (sensors and all) to a post 90 so if any need to know how to upgrade the renix cooling systems, I got the sensor part numbers and list of all parts "needed".
Ill get some pics after I get home from work but it goes right into the back on the bottom of the compressor.PornstaR said:Unplugged what?? the gound on the AC pump. The other wires should be going to the can for the AC. The un plugged ground will keep the AC pump from actually turning on but will strike up the fan.
I thought that might work but i tried it with both the ground and power unplugged, then one of each, both while the engine was on. I have no idea, is there a fuse somewhere that could be shot? I know that it kicks in when the temp gets to 220F or so.Bloose said:I do think the Jeep must be running and not just turned on. Try that and it may help you. I know if my Jeep is running hot enough for the fan to run and I turn off the Jeep the fan stops. If I then turn the key to run the fan does not come on. Then if I start the Jeep the fan runs again. Mine is a '98. So I'm thinking you must have the Jeep running. Plus I think the Jeep must be running for the AC compressor to cycle on so it would stand to reason that the fan won't come on until the Jeep is running.
HTH,
B
