uvaldetxj
- Uvalde, Texas
This question is for Renix-era jeeps.
My Question :
Do any of you all know what wires go connected to the battery, by factory standards. My - only had the - ground connected to it, but my + has the + battery cable plus the medium thick wire that goes to the solenoid near the relay block plus another wire that came from the wiring harness. My problem is that last wire, i don't think that's the way it's supposed to be. It's like a 10 ga. red wire, and there are quite a few that look exactly alike.
What Happened :
Yesterday I was driving around here on my property when I heard a buzz coming from somewhere behind the dash. Well the jeep started getting sluggish and then just shut off. There was a little bit of smoke coming from the area around the fuseblock. I opened the hood and that wire from the harness to the battery had melted. I cut that wire and reconnected a wire of equal thickness to the battery just to get it back home. It ran just fine.
The Symptoms :
If I turn my key to the "on" position, the lights and stuff still work but if I try and start the jeep it won't do anything. My signals aren't working, but i'm going to blame that on a bad ground because there's a green arrow lit up. My wipers weren't working, i don't know if that has any relevance.
thanks in advance.
1987 XJ 4.0 AW4 NP231 D30 D44
My Question :
What Happened :
The Symptoms :
thanks in advance.
