h-townxj
- Hanford, Ca
Hey guys so on my jeep right now with my avenger sc I'm using 36lb/hr injectors and 8# boost
Current issue
Seems to be pulling fuel under high load and rpm my afr slowly increases through the rpm no matter what at the top of the scale I can't get lower than 16:1 on my data logs wot pulls. Even with 99 entered into the corresponding cells.
Also I am getting a CEL for o2 sensor high voltage though that's likely from my crappy part throttle tuning.
Question
I only have my front o2 sensor hooked up should I have the rear instead or both.
Also I just realized I never added in my resistor to the one o2 sensor I have wired could this be the problem also?
Could it also be my map voltage map? Or possibly I have a crappy o2 map lol.
If it's my maps that is ok I plan on getting it tuned soon. I just want to have it wired correctly otherwise I will have wasted a 4.5 hour trip to LA area.
Thanks I really appreciate any answers you can give me I'm tired of fighting this thing. Just ready to take it to a professional but they can't tune well if I didn't clamp the map correctly or wire the o2 correctly.
Ok I'll shut my mouth now.
Current issue
Question
