Thanks Jes. I finally got around to taking the front apart, as I found out my rear axle had crap tons of water in it somehow, and I was taking care of that first.
Well, I adjusted the spindle bearings, and tapped them further into the spindle, allowing more of the splined section of the axle shaft to come through. I just did a test fit and I can now get the hub body on the side I worked on. Now to put the hub back together, do the other side, possibly replace the other hub. Thanks for the help.
Then I have to fix the trackbar, rotate the axle some, fix the rear locker cable, oil change, seafoam, plugs, t-case, etc.
