keep0njeepin0n
- Beaufort, SC
I just got these as a gift for my 98 XJ. http://www.quadratec.com/products/97036_00.htm
I was wondering, on my last 99 XJ I had a cheap set from Walmart and just wired them directly into my reverse circuit without using a relay or anything. Would it be ok to do the same with these new ones? It came with a 20a relay and fuse, so I would assume that I could just tap into the reverse lights using the 12v wire and a good ground.
The lights are 55w, but still 12v and with a 20a fuse and relay.
Thanks in advance.
BTW, these would only be illuminated for 30-45 seconds at a time MAX if that makes a difference!
Thanks in advance.
