35.
The 8.8 is great diff in many respects. If falls short in a couple of areas, though. The carrier bearings are on the small side when compared to a 9" or even a 44 for that matter, and are much smaller than a 60. By far, however, the case and tubes are the weakest link. I think to use an 8.8 hard requires some prep work, including fully welding the tubes to the case, and then trussing the case and tubes together. Also, I would definately run a crush sleeve eliminator kit when you set up the gears, and I would get away from the flanged yoke assembly and get a real yoke that affixes the joint with U-bolts. If you are going to be sending serious power through the 8.8, I would also want to get some larger carrier bearing caps, very common in the Mustang drag scene.
I should note that ARB has addressed the weak link in the old 8.8 ARB by making the case 2 pieces instead of 3, an by adding a 3rd side gear to the assembly to spread torque loads over a larger tooth contact area.
