Thanks. I swung into an Oreilys because one burned out. I handed them the relay asking for a replacement and you would have though I handed them a hamster.
I just spit coffee out my nose.
I've had a putco harness for almost a year, I have factory fog lights. After having the issue with both lights staying on I searched a little deeper. The Fix was easy no problems since! I recommend it if you need something fast and simple
This. Can you solder? Do what I do cut the grounds solder some wire and run them back up the harness and right to the best ground the battery. I have ran 4 with pilot relays with zero issues.
