Kingkong0192
- New Milford, CT
I've constantly seen people complaining that the Putco harness is junk, the relays are junk, the crimps don't come tight enough, etc etc, the list goes on.
My question is if i were to build my own harness where would i buy the H4 Headlight adapter? (The thing i plug my H4 bulb into?)
Also where would i buy the Adapter that goes from the putco harness into the stock harness so it can act as a trigger?
I circled both of the parts i'm going to need to buy. (I'm also going to need to buy the adapter to the left of the right circle.
I was planning on simply running the entire thing out of 12 gauge wire. Nothing else. Just all 12 gauge wire. Think this is plenty enough to run 100 watt bulbs, or should i step it all up to 10 gauge?
Oh, and for the relays. I've never used a relay. How do i even buy these? What do i look for? Where would i buy the adapter thing that the relay would plug into?
I also plan on running two inline fuses on each low and high beam just for added safety.
