I like to pull it as a complete package but that's up to you.
I would recommend pulling the fuel rail off the intake manifold and tying it to the brake booster rather than undoing the quick connects. Every time I mess with the quick connects I regret it, the parts stores around here don't have the right O-ring and clip assortments to make them stop leaking. They do have fuel injector O-rings, for like 2 dollars for 12. Easy choice.
Also, pull the power steering pump off the engine and drop it where the air filter housing came out without disconnecting any lines, save yourself having to bleed the PS system again.
If the serpentine belt tensioner bolt won't turn freely, sneak a propane torch down under the intake manifold and roast the "knuckle" the pulley bolt and tensioner bolt go through for a few seconds. Try to avoid heating the tensioner bolt, just the knuckle is best. It should turn loose with some persuasion. Try not to break that bolt, it's a dealer only one, what idiot decided an 8mm bolt should be that long and exposed to the elements past where it threads in?
I like to run a tap (preferably bottoming, but whatever's on hand) through all the motor mount bosses until they bottom out, then brakleen flush the cutting oil out and loctite in the bolts. Keeps rust out and everything threads in so much nicer when the threads have been chased all the way to the bottom.
