vdel20
- COLUMBUS, OHIO
Just purchased a 2000 XJ Sport with 112,900 miles very good condition. From what I have been told by another member the Jeep just needs regular problem areas addressed: valve cover gasket, RMS, oil pan gasket, rear diff gasket, driver seat bracket and evaporator. It has some small spots of rust but everything works and the tires are good. It was a one owner vehicle that appears to have been garage kept. This is my first Jeep and at 60yrs I hope the last car I have to buy.
Here's the build sheet I just got from Chrysler:
Sales Code Description
M5 Prem Cloth Hi-Back Bucket Seats
AZ Agate
AA4 Sport Value Group
ADAP Light Group
APAS Monotone Paint
AWHP Power Equipment Group
A20P 4.0L Engine(ERH)/4Sp Auto Trans(DGS
BASS 124 Amp Alternator
BCDS 500 Amp Maintenance Free Battery
BGAS Power Front Disc/Rear Drum Brakes
CADP High Back Bucket Seats
CBWS Highline Door Trim Panel
CDBS Reclining Front Seats
CFMS Rear Fold w/Removable Cushion Seat
CGGS Traveling Inboard Seat Belt Buckle
CGWS Next Generation Front Air Bags**
CKAS Carpets - Floor and Cargo Area
CKNS Cargo Compartment Carpet
CKTS Cargo Tie Down Loops
CKXS Plastic Liftgate Trim Panel
CLEP Front & Rear Floor Mats
CSAS Spare Tire Cover
CSRS Passenger Assist Handles
CSSS Lift Gate Assist Handle
CUFS Full Length Floor Console
DGB All 4-Speed Automatic Transmissions
DGSS 4-Speed Automatic AW4 Transmission
DHAP Lock-Up Torque Converter
DHNS Command-Trac Part Time 4WD System
DHSP Floor Mount Automatic Shift Lever
DJKS Dana 30/181MM Front Axle
DMDP 3.55 Rear Axle Ratio
DRAS Corporate 8.25 Rear Axle
EAAC All Engines
ERH 4.0L I6 Power Tech Engine
GAL Deep Tint Sunscreen Glass
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEEP Deep Tint Sunscreen Liftgate Glass
GFAS Rear Window Defroster
GNAS Rear View Day/Night Mirror
GNCP Sun Visors w/Illum Vanity Mirrors
GTS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMP Remote Keyless Entry
HAAP Air Conditioning
HGDS Deluxe Insulation Group
JAYS Instrument Cluster w/Tach
JBFS Instrument Panel Black Bezel
JCDS 100 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBP Rear Window Wiper/Washer
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPAP Power Windows
JPBP Power Locks
KDPS RADIANT SILVER MET. C/C - BADGE - CH
KGPS RADIANT SILVER MET. C/C - BADGE - JE
KRPS RADIANT SILVER MET. C/C - BADGE - 4
KTPS RADIANT SILVER MET. C/C - JEEP
KVPS RADIANT SILVER MET. C/C - BADGE - SP
KYPP RADIANT SILVER MET. C/C - 4.0L
K2ZS BLACK - MOLDING - BODYSIDE
K3XS BLACK - FENDER FLARES
LAJS Headlamps On Warning Chimes
LBBP Courtesy Lamps
LCDP Map/Dome Reading Lamps
LDAP Underhood Lamp
LDBP Cargo Compartment Lamp
LHDP Headlamp Off Time Delay
LMAS Halogen Headlamps
LNJ Fog Lamps
LPSS CHMSL Lamp
MBKS Black Front Bumper End Caps
MBLS Body Color Front Bumper
MBSS Black Rear Bumper End Caps
MBTS Body Color Rear Bumper
MCAS Front Bumper Guards
MDAP Front License Plate Bracket
MFBS Body Color Headlamp Bezels
MFKS Body Color Grille
MHAS Black Windshield Moldings
MMCS Rear Qtr Solid Window Insert
MMGS Belt Moldings
MMKS Body Color Drip Trough Molding
MNAS Black Door Handles
MNNS Body Color License Plate Brow
MWGP Roof Rack
NAA Federal Emissions
NBKS EVAP Control System
NFAS 20 Gallon Fuel Tank
NHM Speed Control
PX8 Black Clear Coat
QX8S Black Clear Coat
RAAC All Radio Equipped Vehicles
RAZ AM/FM Cassette Compact Disc Radio
RCRP 4 Speakers
RDDS Fixed Long Mast Antenna
SBAS Power Steering
SCGP Leather Wrapped Steering Wheel
SDAS Normal Duty Suspension
SHAS Front Stabilizer Bar
SHCS Rear Stabilizer Bar
SUAP Tilt Steering Column
TBCS Compact Spare Tire
TBLS Inside Mounted Spare Tire
TRLS P225/75R15 Wrangler RT/S AT Tires
TZAP Goodyear Brand Tires
WJ5S 15X7.0 Full-Face Steel Wheels
WLYC All Steel Wheels
XCYS Upgraded OBD-II Connectors
XJFS Tethered Fuel Filler Cap
XPFS Protective Coating and Remover
YAAS Build To U.S. Mkt. Specifications
AZ Agate
ADAP Light Group
APAS Monotone Paint
EAAC All Engines
JPAP Power Windows
JPBP Power Locks
LBBP Courtesy Lamps
LDAP Underhood Lamp
LNJ Fog Lamps
LPSS CHMSL Lamp
MMGS Belt Moldings
MWGP Roof Rack
NHM Speed Control
RCRP 4 Speakers
SBAS Power Steering
