thanks, I'm kinda mocking up my lower arms now, and the most I can move the links is 5" away from the frame...and almsot 6" if I do some exhaust work, and that's the furthest inner tab...so the center of the RE joint will maybe be about about 3.5" to 4" from the frame.
This is only becasue I refuse to mount the arms to my crossmember, and I need them to not hang below my frame. I will be cutting my stock control arm mounts off soon so I can better mock it up, but I have a feeling it's not going to work with straight links, anybody bend 1.75" 3/8" wall without breaking their bender?
kid, can I get some pictures of yours only 2" from the inside...how high up or down low are they mounted? seems low if you're talking about the DS being close when drooped. where did you mount the links on your axle to make them fit? and what the hell is SOP?
Thanks for the numbers _nicko_
