CodyJames
- Olathe, KS
Well my XJ has many problems. BUt stiil drivable. When it idles is studders alot. Like it mis fires every 5-9 seconds. This is not a heat soak issue because it does this when its cold or hot.. I know what heat soak is. I get it alot. Well the big problem is anytime I give it say 85-90 throttle it messes up. It kinda misses or somthing. Its cold and I have a pipe running from the cat back with no muffler if that has any cause or effect. It makes a little "pa....pa" sound? I can feel it slow the acceleration process.
First gear sounds like this if I get on it hard.
VVVVRRRRROOOOO pa...pa...OOOMMMM
