Power Steer pump Bracket
pejeeper
NY
I am converting an 87 MJ 2.5 ltr from manual steer to power steer. I need to know if the bracket that the manual belt adjuster / idler pulley sits in is different than the PS pump bracket. I have the PS pump, but there is no belt adjustment hardware on it. I didn't think to check when I pulled the pump from a PNP a couple years ago.
Any help is greatly appreciated.
Thanks.
Thanks.
OK, I found what I need. The bracket for the PS pump is a separate bolt on piece, someone else musta scavanged it before I scavanged the pump.
Crisis averted....for now
