I have an 89 Cherokee pioneer with power door locks only.
For some reason or another, my locks just dont get enough power to turn over. So I investigated today:
With every door connected, only the front locks work, and barely. The back locks dont work at all. AS SOON as I disconnect one lock, my tailgate lock works, and my front locks work very good. It doesn't matter what lock I disconnect to try this. If I disconnect two locks, then my back left locks works very good. Seems like they're not getting enough juice aye?
So I looked in the wiring diagrams in my haynes manual, and there is an always-hot red wire that goes from the battery to the front switches. I tested this, and it got 12+ volts. It seems good. I tested the voltage at a door, and it only got 10 volts. However the interesting thing is, if I test the unlock side of the connector, and it gives me 10 volts, the lock side of the connector gets 2 volts.
I started up the engine and my doors suddenly got 11.21 volts, and, with two locks disconnected, my back left lock worked completley, although slow.
So to recap:
Each connected lock works better if other locks are disconnected.
Each door is getting <10.5 volts when I hit the switch, and the opposite connector is getting <2.5 volts.
The hot wire is getting >12 volts.
The ground at the driver's side, with the batt disconnected, is getting <1 ohm to the neg batt cable.
So my questions, is each door SUPPOSED to get 12 volts each? I'm sure if each of my doors got 12 volts each + the amps that go along, they would work perfectly. Anyone have an idea what's up?
So to recap:
