positive camber after lift
Adjustable Ball joints can be used to adjust camber. I recomend going to MADXJ.com for write up on those.
When you affect change to the axle geometry, you affect all the settings, not just toe, and not just caster, but also camber.
Why?
Because in the course of lifting the vehicle with stock control arms, the axle rotates the bottom back. This changes your caster, which in turn changes your toe in, and your camber [because it is based on the location of the ball joints, which you moved a few degrees by rotating the axle].
Getting the caster "correct" on a lifted XJ is a matter of making lemonaid.
The FSM wants the pinion in-line with the front drive shaft and that is adjusted via the adjustment ponts on the LCA body mounts. Drivability will call for restoring the caster to somewhat closer to factory specs, which rotates the pinion down and out of optimal DS alignment.
What most people do, is get longer LCAs to "fix" the caster, and live with the fact that the front DS/Pinion are no longer straight on, but a degree or two off. They also don't worry about the camber.
Jeep had a factory option, the Up Country package, which was 1 inch over stock. All components are the same as a non-optioned Jeep, and the DS/Pinion alignment is set per the FSM. You are 1.5" inches over UC package "Stock". If you want, you could go with a bit longer LCAs, but I would simply stop looking at your axle if your toe in specs are right, the pinion is at or slightly below the front DS line, and the Jeep drives well.
Ron
