meatplow5150
- Gilroy, CA
While climbing in 4wd, I noticed an intermittent "popping" or "knocking" sound.
I have a 4 1/2" Rusty's lift, 3/4" spacer, adjustable UCA's and LCA's, Rusty's H/D trackbar mount, and a engine/transmission skid plate, also from Rusty's (recently installed).
After closely inspecting the underside, I noticed that it looked like the front driveshaft had been moving to the right enough to hit the belly plate. You can't see it in the pic, but there are rub marks on the shaft yoke as well...
...I also noticed a gouge all the way around the slip joint, and the grease zerk got knocked-off...
It seems painfully obvious to me WHAT was happening. What I don't understand is WHY it is happening? Does the front axle move that far from side-to-side (on level ground, there's almost six inches of clearance between the drive shaft and the skid plate)???
