- Rainy side of Washington
It could be... my question is whether it would help significantly.
Agreed. The one sitting here decorating my desk at work has some pretty rough edges, I imagine they must result in fairly significant stress risers, smoothing them out would probably help a lot. And that's where about 4 different mechanical engineers will probably tell me I'm using all the wrong terms...
badass hand injury, time to flip off everyone you know .!..!.
whats the plan for the ends of the truss? are you gunna make the sides tamper down and meet at the base of the coil buckets?
ouch, that really sucks. I can one-arm a 30 once the shafts/gears are out of it, but it probably could still break my finger with ease.
How are you going to angle the sides? Cut wedges out of the sidewalls of the tubing and bend the top face? It seems kinda silly to cut the top face and half the sidewalls off and then weld plate in, at that point you might as well just make it all from plate. Maybe I'm misunderstanding the lines you drew on it there.
Here is how I did mine. I made it out of 2x4x3/16 box.
i still dont see any purpose of the short side in either of those two trusses. unless youre going all the way to the inner c and either one full piece across the top or at least tied into the housing like xjtrailriders, its not really adding any strength.
