85xjwoody
- Little Suamico Wi.
xtreemathlete said:Today I am replacing the radiator again. It is under warrenty so I can get a new one for free just to iliminate that aspect. The fan is pulling air towards the engine, the upper and lower hose is very hot and full of pressure. The lower hose definitly does not have a coil and all dealers in the state have them on back order. I would like to replace it but still don't think it is colapsing. What is the porpouse of the radiator in the front? The transmision hose coming off of the radiator kinked when I was taking off the radiator so I will have to replace that. Where do I replace the transmission fluid? And is transmission fluid run through the radiator to cool it off as well? Deeper and deeper still without finding the answer.
You can fill your tranny fluid at the dipstick. I am not sure about your jeep but if the tranny has lines going to the bottom of the radiator than the radiator does the cooling for your tranny. That is how mine is set up but I have an 85 with a 2.5 four cylinder. What do you mean by a radiator in the front? Is there air conditioning in your jeep? If so than it could be for the a/c. Have you checked to make sure you are full of coolant? Don't know if you have topped it off again since you have been boiling over.
Kim.
